frankysfree
Make sure you keep an eye on the tierod or steering arm hitting the wheel. With the larger wheel you may not have to worry about it. The good thing is thats solid thick parts on the ody front end. Should be plenty strong to weld a bracket on. Looks good.
How will you control the front brakes? Pedals?
Make sure you post the part number of the bearing you use for this mod. Thanks friend.
I'll make sure the rim clears but the new wheel has less backspacing so it shouldn't be a problem.
I think I'll link the front and back brakes together to a foot pedal, and the shifter will be a lever like a shifter kart with a clutch lever attached to it like a suicide shifter on a bike.
I'll make sure to post part numbers(or at least bearing dimensions) when I get it done.
