Honda GX620 Build
KartFab
Dallas, TX
Honda GX 620 Reassembled
Well, I got most of the parts in the mail and finished putting it all back together. Fired right up, and it charges the battery. Battery reads over 12.5v, and when the engine is idling it was slowly going up, and topped out at 14v, then at full revs it was about 15v.
It had an issue idling, and I adjusted the idle screw so now it idles great. The muffler really makes a huge difference.
It does have an issue though. It looks like with the new throttle assembly, that the spring for the governor is too long, so I may need to order a new one. Time to investigate a little more.
Also, while I was taking off the pull start recoil and cup from the seized spare engine, it unseized. It's pretty much complete, but missing the air filter housing. Ill have to look into it and see if its worth fixing up at a later date.
KartFab
Dallas, TX
Well, after further investigation I will either have to buy a new governor spring, or just take the one I have and carefully measure how much I need to cut, then tig weld it back together in its shorter form. The spring is way too long. It only allows the engine to rev a tiny bit due to its length.
KartFab
Dallas, TX
I know!!! Ive been editing videos for my youtube channel and need to go do some real work. My butt hurts from sitting on it most of the day today.
KartFab
Dallas, TX
Governor Spring
Well, I cut and rewelded the governor spring, might be a little (1/4") short, but I will be able to control the final travel position of the throttle lever with a stop screw.
Also, does anyone know about the knock off magnetos? I have those on my engine and they work great. Im curious to see if they are RPM limited like the new honda vtwins are.
Also, found a leak in the exhaust, so I just welded it up. It still leaks around the area where it was crimped on, so I have to weld that as well. Runs great with the new throttle assembly and the governor does a good job.
KartFab
Dallas, TX
well, i traded 3 bud ice's and $20 for a gx610 with a broken camshaft gear. All i needed was the air filter housing for my other engine... the governor gear broke with the camshaft gear so i think ill bypass (remove) that one and put it on a mini bike....so now I have 3 v-twin engines.
Does anyone have any cool ideas on how to fab up a custom intake filter housing for one of these? Any examples?
Also, this gx610 came with no exhaust so I will make one out of stainless tubing. I dont remember what the parts are called, but I can source the tubing and bends to weld together, but am having a hard time figuring out what the little Y thing is called where the exhaust comes together. I want to Y them together right before the muffler for the exhaust scavenging effect, and want some advice on what a good muffler would be. The tubing would be between 1" and 1 1/4" OD as a point of reference and the displacement is 614cc. I can weld stainless and normal steel, but not aluminum.
So in short, any ideas for:
1) intake housing fab
2) Y exhaust part
3) muffler
