with toystories awesome advice!
I'll just add to make sure your gas can, tank, fuel lines, plus your petcocks sediment bowl is clean and flushed out so you'll be eliminating the possibility of flowing more dirt into your carb.
Sometimes fuel from gas stations pump dirt and debris right into your tank or gas can.
I'd suggest when you you buy gas, you take just a little extra time, to use a clean funnel with a clean paper towel laid inside in a cone shape. This will act as your first fuel filter and really help to eliminate the possibility of crap from ever reaching yer carb plugging it up.
(also make absolutely sure your gas can and tank dont ever have any rust inside too)
Adding an additional in-line fuel filter to your engine would be a good Idea too!
You might find even more helpful info here}
http://www.diygokarts.com/vb/showthread.php?t=10957
FYI, these motors are very commonly used in these type of applications.
Yeah, I've seen several boats setup with GX390's/clones on one of those Swamp Logger or Swamp Man tv shows. Looks like a cool setup man, you'll figure it out
