Honda GX390 13HP Stalling Problems
lftdjeep426
I've got a Honda GX390 that I have running my mud motor on my boat. Here is the deal. It acts like the float is getting stuck possibly and letting the carb bowl run out of gas. I've cleaned the carb and everything moves freely. I am starting to believe that it might have something to do with the levelness of the motor when I'm running it. unfortunately it is intermittent so I can't nail it down. Do you guys have any thoughts on this problem? :huh:
Given the odd application, you may have something with the odd orientation. The engine is equipped with a low oil safety shutdown that normally would kill it if a low oil condition is detected. I suspect this may be your problem. Ensure that you have sufficient oil and then unplug the sensor and go for a test run- then report back. You will find the sensor lead coming from a fitting low on the front of the enging block, and connecting to a small square module.
Also, if the engine is mounted at a weird angle you may have to compensate by adjusting the carb float level or possibly fabricating a new intake manifold that will hold the carb in a level orientation,
lftdjeep426
Awesome! I knew nothing of the oil sensor. I'll try and find it first and unplug it. I actually put a touch more oil than required because I knew I would be using it at different angles.
FYI, these motors are very commonly used in these type of applications.
:iagree: with toystories awesome advice!
I'll just add to make sure your gas can, tank, fuel lines, plus your petcocks sediment bowl is clean and flushed out so you'll be eliminating the possibility of flowing more dirt into your carb.
Sometimes fuel from gas stations pump dirt and debris right into your tank or gas can.
I'd suggest when you you buy gas, you take just a little extra time, to use a clean funnel with a clean paper towel laid inside in a cone shape. This will act as your first fuel filter and really help to eliminate the possibility of crap from ever reaching yer carb plugging it up. (also make absolutely sure your gas can and tank dont ever have any rust inside too)
Adding an additional in-line fuel filter to your engine would be a good Idea too!
You might find even more helpful info here} http://www.diygokarts.com/vb/showthread.php?t=10957
Yeah, I've seen several boats setup with GX390's/clones on one of those Swamp Logger or Swamp Man tv shows. Looks like a cool setup man, you'll figure it out :thumbsup:
lftdjeep426
Here are a couple of pics.
Awesome! Did you fab all that, or is it a kit that you add the engine to?
Also, the prop sorts resembles an auger... You said that's for "mud"- really shallow water? I guess it is more durable and would shove through goo better than a standard prop?
