Honda GX270 charging system question
trkk11
New Lenox, IL
I was just offered a running Honda GX270 for $100. I would like an engine with charging capability because I'd like to put a few LED spot lights on my kart build. The engine does not have a charging system now, nor is it an electric start engine. Is there a kit I can buy with everything I need to make this work? Or could someone provide me with a comprehensive list of what I need. I'd like to see how cheaply I can get this thing to charge a battery. I really don't care if I get electric start out of the deal.... it'd be cool, my kid would love it, but it is definitely not necessary... I just want to be able to hook lights up and not have to charge a battery every time I use the kart. Thank you in advance
The lights I want to put on the kart are 10 watt LED spotlights and ideally, I'd like to put 2 on top and 1 in front, then maybe a couple 1 watt LED strobes on top as well.
One way that I know of is to get an old GM 10si 1 wire alternator. It is offered in a 60+/-amp. It uses a V-belt so you'd need to add a pulley to the shaft of the engine and run a belt to the alternator as well as rig up a tensioner on the bracket you bolt the alternator to. I'd be enough to run halogen lights but those LEDs should be more than half less of a power draw. But it'll have about a 2hp parasitic draw on the engine.
Edit: there is a thread in the FAQ section of the forum for the 10si conversion.
anderkart
Surprise Arizona USA
Honda offerd 3 diferent charging system's for the GX270, (3, 10 or 18 amp output). You could get a higher output (10 or 18-amp) charging system by specal-ordering all the genuine Honda parts you'd need from most any authorized Honda mower shop, or save lots of money with one of the aftermarket electric start kits that typicly come with the lower/3-amp output componets like this kit:
http://www.amazon.com/HONDA-ELECTRIC-STARTER-SOLENOID-SWITCH/dp/B00FOUQ1DG
I saw that... what amperage is that going to charge at? I would think I'd need the 10A
---------- Post added at 01:54 AM ---------- Previous post was at 01:51 AM ----------
And any suggestions on a good battery to go on an off-road kart?
ATV, motorcycle or lawn/garden tractor batteries would work. I know lawn tractor batteries are enough to run the lights and low oil light on a Cub Cadet 2165 and they are smallisg. Battery box would be an easy make. Take some 10ga 1" x1" or even 1/2x1/2 cut 4 the length of the battery top and bottom. Weld 2 8" or 10" bolts to the angle iron in between posts, take a piece of say 10ga flat stock 1" x1” drill 2 holes in it, one at each side, slide it over the battery and I'd use nylock nuts or just regular nuts and lock washers to hold the bracket in place so the battery won't move.
You can get the battery at Sears under their Diehard brand or some auto stores might carry them. You can sometimes find them on sale for like $30 without a rebate.
anderkart
Thats going to be the wimpy 3-amp charging system. The 10 & 18 amp systems cost a lot more, unless you can find used componets...
Wal-Mart has low priced riding mower batterys that are fair quality, or there's a componey called Odyssey Battery I'd recommend if you want a higher quality battery with a longer waranty & much higher cold-cranking/amp hour rating.
trkk11
New Lenox, IL
Anderkart, what is different between this and the 10A? Can I use the components in this kit and upgrade the charging coils? Or is the flywheel and everything different?
anderkart
Yes the 10-amp charging system uses a different flywheel with more magnets, the 10-amp charging coil is also much larger and has 3-wires instead of just the single wire of the 3-amp charge coil. The 10-amp charging coil produces AC-voltage output, so it also requires a rectifier to convert the voltage to DC. This rectifier is dual purpose and also acts as your voltage regulator.
anderkart
This online shop probably has all the parts you'd need, but you'll need model and serial numbers to order. This page on their site lists a model number for an electric start GX270 with the optional 10-amp charging system: http://www.planopower.com/store/honda/index_gx270.shtml
But I'd suggest you call/email them with your engines model & serial numbers and explain your situation to make absolutely sure you order all the right parts...
PS: when I was researching 10-amp charging systems on GX270 engines for you, I noticed some people claiming their 270 engine blocks did not have the additional mounting bosses/threaded holes needed to upgrade from the 3-amp, to 10-amp charge coils. So you might wanna remove your flywheel and check into that before ordering any parts too....
