Honda GX160 engine/clutch Issues..help!
diamondz
Honda GX160 engine/clutch Issues..help!-pics added.
I have been lurking these forums. But I hav not found an exact answer to my problems.
First..te kart has been stored for about 10 months..Now i have problems getting it started/keeping i running.
I have cleaned the carb, but after reading i know that i need to spray oll orafices. I did not do that.
Also, on a youtube video i saw that there is suppose t be a hose with a tps sensor coming frm the carb to engine..I just realized that the hose ws not there. i will check in the am..will this cause the not starting/wont stay running issues?
What type/weight oil should i put in it? how much? the oil looks dark.
Lastly, i have a wobbly clutch, i have no idea on how to get it off or how to repair it...can some one give me a lin to instructions/video, telling me what tools i will need etc. Can it be repaired or just replaced? The bolt is realy rusted.
if replaced...how much does it cost and can i get one lcally? I am i Marietta Georgia.
Any other pointers/suggestions are welcome.
thanks
Welcome to the forum diamondz. Firsty, I would suggest doing a google search and downloading the user manual for your engine. If I am not mistaken, the honda site has all the manuals for download. That will give you an idea of what oil to use, as well as if you have all the parts that are supposed to be on the engine.
Secondly, I would suggest posting a picture of your engine as well as the clutch so that we can see what you are talking about.
For the carb, you must clean out all the little holes and all the jets using something like a twistie with the paper taken off, or with a guitar wire. A thin piece of copper wire (like off a wire wheel) also works well. Make sure you poke out all the holes.
You can also use the lemon juice boiling technique to get rid of all the old gas varnish that has build up
How to clean a carburetor the right way (with lemon juice)
http://ezinearticles.com/?How-to-Clean-a-Motorcycle-Carburetor,-The-Right-Way&id=1460030
http://www.diygokarts.com/vb/showthread.php?t=11976&highlight=lemon+juice
What type of clutch do you have (pic will help here). Clutches usually sell in the region of $40 for anything smaller than a 1" bore. A 1" bore clutch can be over $100
Kaptain Krunch
Pro Junk Collector
vermont
Personally i wont use anything but a stripped piece of 16g or 18g copper stranded wire. wire off a wire wheel is often fairly hard, same with guitar wire, and carb jets are made of brass so it isn't all that hard to scratch then and slightly enlarge the holes after a cleaning or two.
diamondz
Thanks for all your help. I am taking pictures now and will post soon.
Sorry fortune confusion, it is a PVC vent hose. That seems to be missing.
diamondz
This is the picture if the line that looks like a hose should be there.
The vent hose is not a requirement. It is there for emission control. Unburnt gasses in the crankcase are (theoretically) direct to the carb to hopefully be burnt off instead of venting to the atmosphere.
If you find it drools oil occasionally, either reconnect the hose, or just install a hose that reaches up several inches and pop an inline fuel filter on it to keep dust out.
diamondz
ok, i replaced the clutch, but the kart wont take off. It seems to spm really fast with the wheel in the air. but on te ground it won't move. have i done someting wong?
it starts now...but goes dead when i left off t gas pedal. (will not idle on it's own) and it will eventually go dead even though i and giving it gas. it acts lik it is fuel starved..but it is getting plenty of fuel. I am re-cleaning the carburator now. hespark plug is new. What else sould i check?
