Honda GX140 will only run on choke
enzyme
Honda GX140 engine starts first time, runs perfectly apart from even after a long running time, if I start to move the choke from full on to anywhere toward the off the engine cuts out.
The engine (as far as I can see) is in perfect condition, I even have the owners manual and
http://engines.honda.com/parts-and-support...s-manuals/gx140
and have double checked the set-up
I have even double checked that the lever is doing/showing what the choke butterfly is correct.
Apart from that the engine runs fine, no smoke and plenty of power.
I have fitted new spark plug, cleaned main jet and pilot as main jet was compley blocked when I got the engine.
I have also cleaned out with very fine wire any other jets.
I have tried adjusting the only adjustable part of the carb which is the pilot jet and it has zero effect on the engine running.
Any advice?
enzyme
Are there any solvents I could soak it in? I have acess to quite a range via work.
Or would one of those carb cleaner sprays work?
Blazkowiez
Kart Aficionado
Houston, Texas
Mainly we just use any carb cleaning spray we've got around (B-12 is great but expensive when we use 100+ cans a month) and drill bits to ream the jets which are clogged.
I mean, we have an ultrasonic device but you really don't need one of those unless you've got one already.
SmallEngineDave
its sounds lean. sometimes a new plug will do that. there should be a mixture screw on the carb, usually a flathead with a spring. i dont know wich way to turn it. if there is no mixture screw you might have an air leak. those are always a pain in the arse
enzyme
No getting any where with this.
I have fully cleaned the carb with a full can of carb cleaner, new spark plug, new fuel bowl, new inner gasket.
Fully flushed the petrol tank etc etc etc.
One thing I have noted is on tickover it will run with the choke fully OFF, but as soon as I up the revs it dies...does this give a clue?
I have fully tightened everything down, and can not see where an air leak might be.
There is just ONE adjusting screw on the unit and I have tried it in every postion, it makes not difference.
Any more advice pleas?
Blazkowiez
Kart Aficionado
Houston, Texas
The main jet is most likely clogged if it has trouble running at high rpm. Try a new carb out to see if its an issue with what you've cleaned if you have access, if you don't have access to new parts then clean yours again...
Bluethunder3320
Take the carb off the manifold and just pour a lot of gas in so its wide open and see if it revvs and dies... Works on 2 strokes but idk 4 strokes
