Honda gs120 Clutch Help
jeerweezer
How do I test for power from engine to clutch starter?
I don't really want to burn up control box by touching wrong wires together.
When I turn on clutch starter switch nothing happens. Clutches doesn't engage. Or move for that matter
Sorry, I don't really understand what you're asking..
BUT
it's fairly simple to test an electric circuit like that safely..
Everything has two wires/terminals
the battery, the switch the starter itself (a potential solenoid has at least one more even)
never short any of these while testing;
instead measure the voltage between those terminals/wires..
battery should have ~13.5V
Now move the negative lead forward following the wire to it's next terminal until you reach the starter.
you should read the same voltage all the time.
Now move the positive lead forward until you hit the switch, toggle the switch to on
and go ahead until the voltage cannot be read anymore to find the broken part/wire.
or again you reach the starter from the other side.
If the starter 'sees' the Voltage it itself is the culprit.
