Honda clone timing question/not starting
screwloose
Hi there ladies and gents. I've been lurking for a while and thought I would jump in with a question.
I'm currently working on a honda clone gx200 engine (if you really want to know it's a LIFAN which is pretty close to a predator harbor freight clone)
I was doing what some call a stage one upgrade: remove governor, new valve springs, 18 lbs, remove fuel tank and stock filter, replace with a green type filter. in the process I totally broke down the bottom end including removing the con rod....
I can't get the engine to start! when I use a squirt of starting fluid right in the piston through the spark plug, it seems to backfire, but not really even a stutter.
Here is what I've done to troubleshoot:
  • made sure the two timing marks are lined up on the cam and crank
  • gaped the valves at tdc to factory specs
  • installed a brand new carb from a running predator engine
I did get a hose clamp stuck on the magneto on the fan side that got stuck when i was manually rotating the crank. Could this have knocked the timing off? Is there a way to knock the timing off by removing the con rod?:surrender: thanks for having pity on me. I'm sure if I can get this thing started I will be a contributing member.
Check Coil gap with a buisness card.... might have gotten knocked out a bit..
Recheck the valve lash.
Did you remove the flywheel?
screwloose
Didn't touch the other side (fan/flywheel) (except the offending hose clamp that got lodged in the magneto for a second) I'll recheck the valve lash when I have a second and report back. I'll look up how to check the coil gap too. It's getting a healthy spark, I also forgot to mention I upgraded the spark plug to a brand new NGK.
---------- Post added at 10:11 PM ---------- Previous post was at 10:10 PM ----------
Keep on posting, maybe you'll get to be a paid member here like most of us.
A select few of us here are @ .15 cents a word. :D
Glad we've got the peanut gallery sorted out I think big joe and I will get along!:cheers2:
---------- Post added at 10:12 PM ---------- Previous post was at 10:11 PM ----------
Have you checked to make sure that it still has spark?
Good point, yes, I grounded out the plug and have a healthy spark.
Ok so, you have spark but is it sparking at the correct time? Just to rule it out, I would check the flywheel key; you never know...
Umm, we don't usually do both, one or the other; otherwise, what's stopping the stock conrod from self destructing?
screwloose
Was told it would float the valves if I didn't change the springs..... I'll check the flywheel. Re lashed the valves .003. still no start
Ya it will... It'll also help to save the rod through the top of the block... By limiting the revs about 5k.
KartFab
Dallas, TX
A common problem people have with engines that dont know a lot about them out of the gate is
1) the governor isnt just for limiting rpms to 3600-3800, it actually OPENS the carb butterfly when you pull the cord, allowing enough air to get in to start the engine
2) once the engine is running at idle rpms, the governor goes back to doing nothing until you approach 3600 rpms
SO, with that said, what happens when you remove the governor?
The throttle butterfly is forced closed all the time by the return spring, so not enough air gets into your engine.
How to start your engine when its cold, and you have removed the governor?
Choke on
MANUALLY HOLD THROTTLE BUTTERFLY OPEN (do this through twist throttle on a mini bike or foot to the floor on a go kart, or by physically holding the butterfly open with your hand)
Just my 2 cents here.
Also, another pet peeve is assuming something is wrong with the engine when you dont maintain your fuel delivery via the carb, fuel line, and gas tank.
Now with all that said, and you really want to rule out the carb and fuel system as the problem, you take the carb off of your engine, squirt some starter fluid in the intake, and give the cord a yank a couple times, If it doesn't fire up there for a second or two, you know its not a fuel problem.
screwloose
Choke on
Hi kartfab thanks for the tips. This is common practice before I rule out fuel. I just didn't mention them.
Perhaps they will help someone else.
Can I screw up the stock timing by removing the con rod? It really seems like I have pre detination. I'm starting fires off the carb
Sent from my VIVO 5 using Tapatalk
screwloose
Wait, are you saying you removed the piston & conrod from the block? If so, are you sure you reinstalled it correctly?
Left the piston in. Guess I should have been more clear I disconnected the con rod and moved the lower part and left the piston in place. I might have screwed something up because it feels like I don't have compression. I will run a test on Tuesday.
Poboy kartman
Senior Moments Member
White Settlement Texas
What's jumping out at me that hasn't been mentioned is setting the valve lash at TDC.
Well, there are TWO TDCs. You MUST be on the compression stroke!!! It won't work if you've set it on the exhaust stroke.
screwloose
Okay... Makes sense. Might be onto something. I made sure the marks were aligned and pulled off the head to make sure it was at the top of the stroke visually with the cylinder and piston. Will the marks align on the second tdc?
Flyinhillbilly
The great cornholio
North West Arkansas
I haven't checked on these, but I know that on a small block chevy that if you stab the distributor with the dots lined up that it'll be 180* out on timing. The dots are "the other" TDC on one of those.
screwloose
Hillbilly,
If I understand you correctly, the tdc stroke should make the timing marks 180 out (or thereabouts), and this tdc I want to lash the valves on?:roflol::mad2:
Also guys thanks for helping me out on this one. I'm starting to wake up in the morning thinking about gaping valves and lining up cam shafts on gx-200's
Poboy kartman
No, let me explain:
A small block Chebby has 8 cylinders, the Predator has one. The Chebby has to synchronize the timing with a DISTRIBUTOR, a small engine is timed by a key, ( to keep the flywheel magnets " clocked".
Anyway, the ONLY way to be 180° out is if the key is sheared. (Remember the check that?)
BUT!!!! If your valve lash is set on exhaust, the valves will not close properly...( in the correct sequences, perhaps causing a loss of compression.) Sound familiar?
While this puts the engine out of sequencing, it does not put it "out of time" which refers to electrical timing.
---------- Post added at 11:38 AM ---------- Previous post was at 11:31 AM ----------
To make this a little simpler, pull the valve cover. If both valves are closing as the piston is on the way up. That's the compression stroke.
Pull the spark plug and stick something like a screwdriver in it. As soon as it quits going up and wants to go down, that's TDC.
