Honda clone help
Gillgamesh64
Griffith NSW Austraila
But before you get out the sergical gloves try tightening the carby and see if it does not leak, I might work long enuff to buy a gasket... And a brand new carb for one of these is $25 :)
kendelrk
redneck engineer
westland michigan
on ebay? i want brand new, the one palce i was buying it from was 78 dollars, well i have a video, i can keep it running with the throttle a little high and it seems to run but its being a bit *****y ill post a vid in a minte
kendelrk
redneck engineer
westland michigan
**** video wont post because its a peice of ****, well anyway i can keep it running if its a little above the idle. and it stays running, but it smokes, and now it dosent leak
kendelrk
redneck engineer
westland michigan
it smokes , but dosent leak, stays running above regular idle but as soon as the choke comes off, itll run for lik e 15 seconds, but the dies out,
kendelrk
redneck engineer
westland michigan
the carb is totally ****ed now, now i have to come up with ****ing 85 dollars for a carb and 5 for a sheet of gasket material what the living ****
Yes- why wouldn't it be. You've got a GX200 clone right?
I'm not sure I understand why you need a new carb. Unless you smashed yours, it's fixable.
kendelrk
redneck engineer
westland michigan
yeah i do and it may be, but the more i try to fix it the more it gets messed up, so whats the point of trying to fix it once more than to just buy a new carb and go from there
Because if you never learn how to fix stuff, you'll be spending a LOT of money in the long run.... I mean, it's your call- if you want to just keep tossing money at it, that's your business.
Get a manual, rebuild the carb.
kendelrk
redneck engineer
westland michigan
Well after it ran for about 10 seconds, it backfired like out of hell . Now when I pull the cord it gets the flywheel I know but there like no pressure, and it won't run. So I gave it a small spray of gas directy I'n the carb and got nothing still, any ideas?
SmallEngineDave
no pressure, no compression. If it runs for 10 seconds, dies, then it wont start and theres no resistance, theres a compression loss somewhere.
I was too lazy to read all 5 pages, so I dont know exactly what you did.
If you dont have a compression tester, take out the sparkplug and put your finger in the hole (hehehe). Pull it over at the speed you nromally would. I beleive 13psi is enough to blow your finger out the hole. Ideally, compression should be between 75ps1 and 150psi. But you need a compression tester to see exactly how much there is. I think they are no more than $20 at an auto parts store
kendelrk
redneck engineer
westland michigan
it wont start anymore not even a sign i did this and it shot it stright out, but it dosent feel tight, the carbs got gas, is in the right position the needle and float are in correctly, and the spark plug has spark, but it wont run
anderkart
Surprise Arizona USA
#1- it ran great stock only problem was the oil sensor,
#2- then i put on the air intake, and it ran,
#3- then we ran into the governor linkage problems, got that back together and it worked good, but wouldnt run off of choke,
#4- and then i put my header on, it ran good but still has to have choke,
#5- then finally, i did my re jet to number 90, and now its just ****ty,
Sounds like your problems started in step #3. What all did you change, adjust or work on that day?
kendelrk
redneck engineer
westland michigan
i took off the throttle plate, including the arm and all linkage there, so i was left with the governor arm just pushing the throttle, and it had a return spring, which i figured out that it wasnt wrong, it just needed an idle adjustment, so i pout it all back together and tried to run it, and it started. and i did ride it, but as soon as i took the choke off, it felt starving for fuel and died, when i put the choke on and pulled, it started right up, so i thought ok thats enough for today, i put the header on and it ran, and then i did the re jet and it ran like ****, but i was fooling around in the street and i turned the choke off to see and got a burst of power. it backfired and died, i had now lost the idle screw and had been doing it by hand/spring, so i ran to the hardware store and got a screw, and it wouldnt start for ****, so i left it alone after taking apart the carb and putting it back together, next day still no start, and it was pissing me off, so i cleaned the carb again, still no run, so i pulled the spark plug, it sparks, but theres a bit of oil at the end which leads to maybe head gasket? it has gas and gas is getting to the carb. but the plastic idle jet on the side, it used to be really tight, and now it isint, could that also be it?its got gas, spark, and intake, but it just wont run.
