i took off the throttle plate, including the arm and all linkage there, so i was left with the governor arm just pushing the throttle, and it had a return spring, which i figured out that it wasnt wrong, it just needed an idle adjustment, so i pout it all back together and tried to run it, and it started. and i did ride it, but as soon as i took the choke off, it felt starving for fuel and died, when i put the choke on and pulled, it started right up, so i thought ok thats enough for today, i put the header on and it ran, and then i did the re jet and it ran like ****, but i was fooling around in the street and i turned the choke off to see and got a burst of power. it backfired and died, i had now lost the idle screw and had been doing it by hand/spring, so i ran to the hardware store and got a screw, and it wouldnt start for ****, so i left it alone after taking apart the carb and putting it back together, next day still no start, and it was pissing me off, so i cleaned the carb again, still no run, so i pulled the spark plug, it sparks, but theres a bit of oil at the end which leads to maybe head gasket? it has gas and gas is getting to the carb. but the plastic idle jet on the side, it used to be really tight, and now it isint, could that also be it?its got gas, spark, and intake, but it just wont run.
