Honda Clone firing through carb
Stephen115
I recently upgraded my cam and 18Lb valve springs. The engine has been sitting for a month due to the jet falling out while racing. Replaced the jet and went to start and its shooting the starting fluid out the carb and also you can feel the compression shooting out of the carb.
Any clue on why this is happening? and is the valve lash the same as factory when you upgrade the springs?
thank you
SJ
klicky96
Sandusky, Ohio
See, that cannot be it with my engine because It has literally never had the crank case off. I've only taken the head off. And I know the timing is off but Its not the flywheel key either. I might just use it for a project engine.
Stephen115
it could of skipped time inside?
exenos
Project Nut
The the cam might have skipped a few teeth on it own and is now a few degrees off resulting in incorrect timing.
I really can't see that happening. Think about it- the cam and crank gears mesh together directly. Those shafts are supported in their journals by bearings. The only way I could see them slipping out of time (and this is a loooong shot), is if those bearings are literally falling apart, or if the teeth on the gears are literally stripped, broken, or missing. If that is the case, you go much bigger problems than improper valve timing. Much more likely is excessive valve lash (or poor mechanic's work) causing a rocker to slip off the valve stem/lifter.
klicky96
Sandusky, Ohio
See, thats what I was thinking exactly. There is no possible way my cam could jump over and skip a few teeth, just no way. BTW, it an old briggs flatty.
