robbie
I have a Honda ATC 200 that I picked up for cheap from a couple of kids who appeared to not know much about mechanical things. They said they believe that the engine had no spark when it was left a few years ago. But that's about all they could tell me. Also, the starter cover is missing, so it's hard to test anything right now.
If I'm not mistaken, this type of setup has an internal coil as well as the external one on the frame, right? What are the minimum requirements to get the engine to run? Is it just one wire from the engine to the coil, the plug lead, and good grounding all around, or is there more complicated stuff involved? I'm intending to use the engine and rear axle for a go-kart, so all I need is hot spark and a kill switch.
I also bought a second engine in a larger lot of 3 wheeler parts. The guy said it runs. It has a starter but it's just the engine without the spark plug coil. I'd like to mix parts until I get one engine to run.
I need to know how to test the coils. Does anybody here know if the primary and secondary of the main coil have a common ground? Any other words of wisdom?
