) you must attach a cluch unit so the motor will not engage the wheels until a certain rpm. You can either get a centrifugal cluch which is around $40 or a Torque Converter unit for about $200.
You want a small sprocket on the engine with your setup to give it some torque,otherwhise it would probably just stall the engine![]()
