mrbeggs432
I recently switched out a crankshaft on Honda 390....reason being it was from a generator and had a tapered non-keyed shaft.
Things went good...I switched out without removing the head, piston or lifters.
stock crank...removed governor & oil sensor unit ...left the balancer in.....everything lined up puting the case back on.
Put oil in and tried rotating by hand...turned about 3/4 and it stops and you can hear a clunk...like its binding.
I know I have to break it back down but what should I be looking for ???
Please help
Please help
