Honda 20 HP two cylinder
notpretty
Folsom, CA
Help??
I know anything can work for a go cart...if there's a will there's a way...but is this motor in the ballpark for a gocart...larger type with suspension and off road type tires? For use on open land...80 acres rolling hills...
If plans for such a frame/suspension exist post a link of it for me. GoCart supply house for key parts? Links?
I can build it. I build 4x4 rock crawlers...have all the welding and fab skills needed including hydro-tubing benders etc.
Any help would be great.
Poboy kartman
Senior Moments Member
White Settlement Texas
Welcome to the forum.....please fill out your profile...as location helps us in sourcing parts.....
EDIT: Also....go to the general gokart discussion section and read the first sticky..."Big CC engines on a gokart ".....
KartFab
Dallas, TX
Yes this will work for a go kart. An off road suspension type. Is this a gx610, 620, 670?
Transmission should be a 40 series but you will be pushing its limits. May need to look at the comet duster for the transmission and reverse gearbox from a golf kart?
In sure you will fab up some crazy exhaust for it too :)
Chain (like 420pitch) may stretch too much do you may need to get dual sprocket or bigger chain. Gear it to s 6:1 ratio and you will have plenty of torque. 22-26" tires will be good enough on rear. 18-19" on fronts.
Also may need to check for the remote choke and remote throttle kit in the users/parts manual.
Bullfrog Motosport
We have a header kit that we use for our golf carts that would work for your kart project too. We also have valvetrain upgrades for the Honda V twins too. www.bullfrogmotosport.com
We are in the process of fitting this engine in a Carter buggy.
