Homemade muffler
SpyGuy
Hooligan
Tucson, Arizona
is that an altoids tin for your intake manifold? LMAO :thumbsup:
Air cleaner, actually ....when you open the box, there's a couple of layers of screen door material, wrapped in about seven or eight layers of pantyhose. The bottom of the can is drilled for ventilation, plus a larger hole to fit over the mouth of the carb.
This is actually an older picture of the bike. Since then, I've been doing some welding, and fabbed up a new chain guard, upper engine mount, and front fender. If you're interested, I'll post up a current shot showing all the fun little things I've done to it.
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
Post a new pic. I like all the DIY parts.
SpyGuy
Hooligan
Tucson, Arizona
Okay, you asked for it. Here's a collage of the various things I've done to The Rat:
My friends always get a huge kick out of seeing this bike whenever we go out for practice. Considering that this was originally an $80.00 CraigsList special and had been VERY badly abused by the previous owner, it was an interesting rebuild.
devino246
Lynchburg, VA
ya, you did a good job. I got my muffler welded up yesterday(ill post a pic later). The tank turned out to be 1/32" on the top, so i ended up making a huge glob of weld to fill the holes i burned in it. The muffler works great though, and looks and sounds awesome.
porsche930dude
Upstate, NY
i pull both the schrader valves out and dunk it in a bath of water. It takes a special long nose tool though so i supose you could just hold them in but it would take much longer to fill. When bubles stop coming out its full
devino246
Lynchburg, VA
Im making a new pipe for the muffler. Right now its just taped together and I'll weld it later. Any problems you could see?
SpyGuy
Hooligan
Tucson, Arizona
. o O (I think the blue tape will burn off once you fire up the engine .... :p)
Maybe put a small elbow bend on the tip to point the exhaust straight back? Other than that, looks good.
devino246
Lynchburg, VA
The blue tape is there to hold it for mock-up. My muffler is gonnna clamp on the end, but adding a removable bend on the end would be good for use as a straight pipe.
