denhammotors
What could go wrong?
Had a 18cc Weed Eater hedge trimmer that I didn't really have any use for, so I did a bit of modifying so that I now have a little 14" chainsaw. I have had it running the chain with no load fine, but the clutch will slip when trying to cut anything. I am pretty sure it is due to the clutch springs being the incorrect length, so it is not engaging at the proper RPM. Also, I think the clutch sprocket is pretty worn out. Otherwise the saw is perfect, but I do need to make some hand guards for safety and a top handle to hold it with.
