techm80
Can anyone help me out with making an air filter for Tecumseh hm80, thanks.
You should not make the actual filter, unless you have something lying around that can be modded to fit. You need proper filter foam or the correct tools to make a k+n style one.
I'd actually be pretty interested to see what it is you're trying to describe r-chez
Pretty sure you already asked this question like 2 days ago.... here's what i said.
Just make one... go to the hardware store and buy a PVC cap. Drill a hole in the middle and then drill two holes for the mounting screws. Clamp a high flow filter on the outside from apskarting.com or the local pep boys rice boy section and you're all set.
Edit/Delete Message
