Home made gokart twin flathead side project?
Thepartsguy
Picked this up maybe three weeks ago. I traded a clutch for a 3hp with a clutch on it. Then used a can of paint I had laying around to make it look all nice and well... presentable?? Anyway I kept the clutch and traded the 3hp for a home made gokart that had a 5hp and a nice max torque clutch. That’s how this project got going. The kart sat for ten years before I got it. And who knows how long before the PO got it. 66641A8D-C1EA-413B-8739-E8C88C5245F6.jpegBAEA7C26-A2E1-49EF-8B74-678DB092887C.jpeg79A6DA98-0DC0-4B3E-B62F-9A563462D817.png
Thepartsguy
valves were locked up well and did not want to be freed. both gaps were at a loose 18 thousands. tank had two inches of mud and the case had been jb weld repaired at some point. It’s a sad 5hp but a runner so moving along. A2966DC7-01AE-4752-A16E-AF46370F4325.jpeg473554A0-7BAC-41EA-A0AE-2B5434D3BF5F.jpegBAB876E3-CEB3-4FB9-947D-63DEFA639C5F.jpeg
Thepartsguy
chopped all the bars off like normal and tried my darndest to make it look usable but it just doesn’t seem like the best frame ever made. still moving on..BFC1B7DB-3AB1-4832-AEB0-E2583859A331.jpeg
Thepartsguy
I cut all that nonsense out and just made it fit down on the plate. Cut slides so it could be adjusted like a normal gokart engine. Don’t have a picture but yes I finished the plate so yes the engine has a lot of adjustment now.11560674-062E-4A71-B525-0B68AAE579DB.png
Thepartsguy
Mock up of the twin engine setup. Yes it’s a 3hp and a 5hp that’s Just for fitting and seeing what’s what. I was gonna buy a slightly longer live axle then I normally buy and throw the second sprocket behind the wheel hub. Run a simple pivot system for a band brake. But now with all the parts going to the streaker this might not even happen. E417467F-125D-4CF7-A5E0-F80ED0670E6E.jpeg
Thepartsguy
And that’s where this project sits... i Ran a throttle cable to the pedal and there is no brakes or kill switch. the diff works great And is more of a limited slip. Pulls awesome through grass/fields. I have put maybe 4 miles worth of seat time on it just screwing about went down the way to the neighbors and back. It is exactly what it looks like. good for maybe a 10yo if any effort was put into making it usable.
