I want to build a go-kart using a 8 Honda CR250R dirt bike motor + tranny. WIth it the radiator and it's FMF Fatty pipe. I went and found the only 120V american power, wire feed flux core welder on this little island. Now the questions flow into mind:
1. but the first 2 is how would i build the frame to suit the motor size, a radiator, chain drive, and the 2-stroke FMF fatty exhaust pipe. Oh, also the air box + carb. That will be my first issue, fitting all that on some sort of semi light steel frame and my 200 lb, 5 11 hind end.
2. Should I use the existing clutch system that is in the tranny and build some sort of clutch petal or clutch handle? I'm trying to keep it as cheap as possible, while still being limited to a welder and normal power tools for cutting (no oxy-acetylene, band saws, or plasma cutters) I'm a low income Sergeant is getting fed up with golfing with the neighbors.
3. Can I make my own axle or is it cheaper and lighter to use a prefabbed. Keep in mind that I have to ship everything to an FPO-AP address which gets me stuck with some suppliers.
I noticed Northern Tools had the 1" axle with 1/4" keyway. Shipping cost unkown, their website said "I" must call due to "FPO-AP". Well that ain't cheap from Japan, guess I need to go ahead and order Vonage.
And i've found H.D. 1" axle sprocket hubs and H.D. sprockets to fit my #520 chain.
Thanks
S.C.
Thanks
S.C.
