Hoda 5.0 "Hunting" Idle
qtband
St. Louis, MO
I have this Honda engine off a power washer and the idle is hunting. I understand that these engines didn't have an idle set when it was installed because it didn't need to idle on a pressure washer. I think the air mixture screw has a limiter so I can only turn it 1/4 turn either way.
Anyone have a solution?
Sometimes engines that are on pressure washers don't have an idle screw that does much. If this is the case with yours, you might need to get a carb that is adjustable.
I would give the carb a good cleaning first before I look elsewhere though. My lawnmower hunted like that, and all it needed was a carb clean
qtband
St. Louis, MO
I did the kart for my brothers grand kids, so it's not too close to home. I found this in the interwebs. It's the same set-up as mine. BTW, it's a GC160.
Ok, I'm just a little lost here. You said that in the original incarnation, there was no idle provision, right? Which I assume means that there was no hand throttle. Just governor direct to carb, right?
Sooo... How are you getting that thing to idle? (Or any throttle control for that matter?)
qtband
St. Louis, MO
What I mean by this is....I have the exact same engine on my pressure washer. When you start it, you put the throttle to full. If you lower the throttle, it has a momentary switch that cuts the engine. The switch kicks in just off full throttle. On the go-kart engine, I just disconnected the switch. When I did this, I can get an idle but it's too high. When I lower the idle adjustment, it hunts.
Ahh- I understand now. Thank you for the clarification. I think I would start by ensuring the governor is adjusted correctly. Then (assuming the carb is thoroughly clean), I'd crack into the idle circuit, starting with the jet. Since that engine was never meant to idle, who knows what's in there? Size the jet, and compare it to a GC that was intended to idle.
I've never done it on a GC, but it generally works like this-
1)Loosen off the pinch bolt that holds the governor arm to the shaft (that goes through the block
2)Rotate the arm until it puts the throttle butterfly at WOT. While holding the arm there:
3)Rotate the shaft in the same direction until it stops. While holding that, too:
4)Tighten pinch bolt.
