Hi !
Outstanding, Conrero. ❤️ The fuel tank looks very nice on the engine and gives it a special look.
Can you tell us the wheel and tire sizes? I think they give the kart "a perfect stance" from the side view.
I dont feel like anything less than brass for the material will sufficiently allow those sleeves to act as stoppers, reliably. I bet you hit lock 10-15 times and it will be wore through. -Or are you considering these consumable?
I feel like you wont even notice when they do finally wear through and the whole thing youre trying to prevent will have happened.
Id really like these to be stronger than I suspect because that would be an awesome solution for an issue with a gas pedal, for me.
If you talk about silicon parts, yes, about à Time, they are used, but they are différent nuances of material for durability. Shore 35/40 is good and very strong. In fact, i Try to limit the wear of paint frame and the only way: test on the ground!
Ok, breaking out the shore durometer measurements.. That actually explained it perfectly.
We Américains say, “the price was so good, it’s like you stole it” That kart is in mint condition (or close to it). Even has the decals, stickers and tags intact. Pity about the missing motor and whatever running gear it once had. Very interesting to see a Manco far from its native country. :love:
50EUR = 58.57150 USD
Here’s a parts manual. Per item 74 it would seems to have had a Briggs 5 horsepower engine and a torque converter…
