Bought new df200gka broke it in changed fluid n plug ngk plug then built custom copper intake to uni airfilter took stock airbox off and put home made header to aftermarket amazon silencer runs rough mid to full throttle under load breaks up and has no power in higher rpm more power low end for sure....problem being cant get into stock carb bowl to put bigger jets riveted together from factory also no air fuel mixture screw any suggestions would be awesome thx!!
