HHOwater4Gas
CarKit
Back in May, "mhan" posted a threat about using the hydrogen from water to run a kart. I explored this and found it use on cars. Does anyone know of it being used with karts? Any joy?:auto:
oranges48
it doesnt give you more energy than you put in, it just burns the fuel more efficiently so you can use less gas.
frederic
The Junk Man
New Jersey
You can run a combustion engine on hydrogen, but the compression ratio of gasoline engines is not optimal for hydrogen, it's optimal for gasoline. A higher compression ratio in the 13:1 or 14:1 range is more beneficial/efficient/etc
Making hydrogen out of water requires electricity. and a lot of it to get any quantity. You also have to devise a pumping mechanism to pressurize the hydrogen it draws from your separation/holding tank into whatever storage facility you've devised (usually an old welding bottle of some kind).
While hydrogen burns more efficiently than gasoline, making it is very inefficient but in a sense that's okay because what you're doing is creating "deferred pollution", meaning that you're not creating fumes in your backyard as you would by running a gasoline or diesel engine on your property.
The major eco-advantage of this is within city limits where everyone has such a vehicle, and the power plant is far, far away, outside the city limits. Pollution in the city will subside and the air will be much cleaner, a goal of every major city these days.
It's a fun experiment, and I'm not trying to discourage you in any way. I've done quite a few alternative fuel experiments myself with several friends and we learned a lot and had an awful lot of fun as well.
I and my friends have run old engines (gas and diesel) on everything from hydrogen to propane to acetelyne to Zep cleaning products.
Some worked, some died an early death, some exploded with great fanfare.
All, was fun ;-)
lemegacool
got boost? :)
quebec canada
running a hydrogen reactor onboard would be very inefficient as you would need a huge quantity of electricity to run the reactor... and guess where that electricity would come from... your engine's output shaft... witch wouls make it drink more fuel and therefore cancelling the "fuel saving". on another hand, adding hydrogen (from a tank) could be interesting... but i prefer adding n2o LOL
