HFT welder
pttm
Rusty.
The thumb of Michigan
Hey guys I'm back again I got a Chicago electric 90 amp flux welder form harbor freight for 90 bucks. I want to use it to weld the regular 2.4 mm wall tube. Do you think it will work?
Felineman
Death by misfortune
Muskoka Lakes,Ont
120 or 240 volt? are you using fluxcore or welding gas? what size diodes does it have? Many factors can make a welder operate like crap. Are you using extension cords?
KartFab
Dallas, TX
Looks like you could weld 3.17 mm thick (1/8") material with that welder on a single pass.
Just make sure you follow the instruction manual and practice your welding if you are new. The welder will do just fine for that application.
pttm
Rusty.
im using 120 volts flux wire no extension cords 0.030 in. size diode i think.
firemanjim
Just kartin' around....
Houston Texas
You want to use. 035 wire, preferably (by me ) Miller wire. You can get 1lb rolls at home depot.... Cheap.....
You can weld. 090" (2.4mm) wall on low with the feed set around 6-8..... More than. 090 and you gotta step up to the high setting.:thumbsup:
Harbor freight welders get a lot of crap dumped on them, but I love mine. It hasn't ever let me down. I have had it for more than 8 years and it's paid for itself more than 10 fold.... Just take of it and don't abuse it. Treat it like it belonged to the Pope, and it will be kind to you..... :lolgoku:
EDIT..... It's the same 90amp flux core you have.....
Felineman
Death by misfortune
Muskoka Lakes,Ont
Yup I replaced the diodes in mine to 600 volt 1 inch from the 12 watch battery sized ones that were in it and now I can weld 1/4 inch plate and even sometimes burn right through it. Good welders only the diodes are crap. I agree on the .35 wire its better. I bent the plate that they used to mount the diodes on up and drilled holes in it for the new diodes. Watch which direction the diodes are they only pass current in one direction. Kinda wish I had upgraded the cooling plate too I don't have that long of a duty cycle.
DaiSan76
Nixa, MO
It has been mentioned already, but I will reiterate. Don't use the wire from harbor freight. Buy Miller or Hobart wire.
supermanotorious
Winchmaster 5000
New River, AZ
I'd love to see bigger images of this, its a mod I would do on my HF 90 amp welder
