HF Clone mounting bolts?
mike75925
thinker and tinkerer
Alto, tx
i want to say 5/16" by 1/4" longer than the mounting plate and motor mounts are tall. get washers and ny-locs. i used carriage bolts this time, because in the past i used regular socket heads and it chewed up the mounting plate. not so with the carriage bolts.
mike75925
Alto, tx
should, on the pto shaft where the clutch mounts, there should be a 'baggie' with a rubber band around it. this is done to keep the key and crank from rusting together while awaiting purchase. if not on the crank end, search the box. if you absolutely don't have it, a foot of key stock is like $5? some of the clutches have the key made into them though.
parker88
Clinton, TN
Ok I got my clone and i see how the throttle should be set up but im wondering if there is something else i need to do because the thottle lever seems too stiff moving it back in forth to really spring back when you let off the gas on the kart???
That's because these engines are designed to be used on an implement at a constant RPM. Set the throttle by hand and leave it there. In our case, you have to slightly loosen the bolt that the throttle lever pivots on, and install a spring to make it spring back to idle.
parker88
Clinton, TN
ok cool i gotcha...i loosened it up and it seems to move freely. Thanx
Which method is the best for the actual thottle hook up?
solomon
ca
You really just make your own, look in the threads, i think their is a topic on it
parker88
Clinton, TN
Allright ive got a question...Is there any way to add one of thoughs cable barrel things on the end of regular 1/16 wire rope???
For the throttle, you can use a bicycle brake cable, and the conduit (tubing, sheath) for it. If you buy it as a new, universal kit, it'll come with one end already swaged on.
parker88
Clinton, TN
Allright so heres what ive got so far and it dosnt seem to be working to good and i havnt found a way to connect the cable to the throttle lever. I NEED HELP!!!
