HF 79cc Carb Problem
rgvkid
Charlie Don't Surf!
Los Angeles, Anaheim
Its been awhile since I've been on the site because I had the Kart stored up in the corner of the garage for about a year.
I pulled the kart out today and it wouldn't start. So I pulled the carb, took out the float and the Piston thats connected to the float which lets the gas flow in, Not sure what its called.
Took out the jet that screws into the center cast tube and I had to clean it out with some .025 welding wire because it was gunked. I ran the wire through the jet that sits up in the cast tube also to clean it out. I cleaned the piston thats attached to the float and the sleeve also. Sprayed carb cleaner throughout the whole carburetor to clean out any gunk. Put everything back together and got it started.
Now the problem is, it will only start with the choke on but the idle is low. When I move the choke back to turn it off, the idle jumps up and it dies. Tried playing with the idle to no avail.
Not quit sure what to try next. Is there a Jet needle on these carbs? Because I don't think there is on this one unless I lost it while cleaning.
I tried looking for a carb Schematic but I can't find anything on it.
I did have to clean and adjust the the rubber tip on the piston attached to the float because when I first put it back together the gas just kept flowing into the bowl and seeping out the overflow all over the floor. So I took apart the bowl and pulled the float and piston again to clean it better and I pushed on the tab a bit to get the piston to seat a bit tighter. After that, the overflowing stopped.
Any insight would be greatly appreciated.
firemanjim
Just kartin' around....
Houston Texas
Try cleaning it ,again..... It sucks ,but Ive had to clean the same carb 3 times in one day.... You coulda missed something..... It happens.
rgvkid
Charlie Don't Surf!
So I pulled the carb apart and boiled it in lemon juice for about 25 minutes.
Put it back together and it seems to start up and run but I'm still having a problem with the choke.
Also, I'm not quite sure what the screw is for that's closest to the intake on the cylinder head. I think it's for the low end. Right now I have it out at about two and a half turns.
Here's a video of how it sounds and what I'm talking about.
http://www.youtube.com/watch?v=4kwTIEunzoA&feature=youtube_gdata_player
rgvkid
Charlie Don't Surf!
Sorry about that.
I set it now to Unlisted so only those that can link it can see it.
FYI, I removed the governor awhile back.
Gonna have my Girlfirends son ride it around today so we'll see how it feels.
