HF 6.5 clutch? basically i need help.
patrick824
Hey guys,
So i havent messed around with my go kart for a couple years and just impulse bought a HF 6.5 new. I dont know much on the whole clutch, sprocket, gear ratio, governor, etc. etc. deal, so bear with me please :). as far as i can tell i have a 72 tooth sprocket on the axel that is roughly 8-9 inches in diameter. my wheels are 11 inch. i do not have a chain. included are pictures. so basically i am wondering what clutch and chain to get. i am VERY tight on cash but i would like a good product (i know, tough request)... thanks so much!
sorry it was dark and i used my phone :/
brendonv
Australia, Perth
10,11 or 12t on the clutch will be fine. 10t for more acceleration but 12t will be fine. 10t will give u a 7.2:1 ratio and a 12t will give you 6:1 which is pretty standard for most karts.
patrick824
What size chain? Also I know I need a 3/4 bore, but what about the other numbers? Ex. (40,41)
patrick824
Thanks guys, what kind of clutch should I get? I see different clutches are rated for different horse powers and I wanted to get your opinion. Thanks
DustinWolfe
Meridian, Idaho
i have that same exact cart frame . mine doesnt have the rear end anymore as im making it a live rear but i still have the old parts. mine came with a 3 horsepower briggs, an 11 tooth clutch and the chain is a 35p. i assume this is all the same with yours.
patrick824
That's the same engine I had too! I think I'm gonna go 10t for a little better acceleration and take advantage of 6.5... I am just worried about the fact that all of the wheels spin independently and possibly just spinning the sprocketed tire with too much accel. We will see I guess. Does anyone know of a good 10/11t clutch, #35 chain with a 3/4" bore that will support a 6.5 hp?? I have heard of these engines being modded to dish out around 20hp (not saying I'm gonna do this but I will probably try to get a few more horses... I know it's a lot to ask for but I'm kinda broke so cost efficiency is key... Thanks!!!
Blazkowiez
Kart Aficionado
Houston, Texas
Its 35 chain, your basic choice for a clutch here is just a 3/4" bore 12 tooth MaxTorque or Hillard clutch, these are standard and can be found at Northern Tool, Tractor Supply, Ace Hardware, or any one of dozens of online suppliers, try not to pay more than 40 for a clutch. Have fun dude.
r97
Measure twice cut once
Massachusetts, USA
i know it's bean said but i though i would just put it all in one post,
11th item down the page sku#4041, http://www.bmikarts.com/category/Clutches-Torque-Converters-Belts-168/rec/30
a little more expensive but it includes the 10(or11) tooth sprocket for #35 chain your looking for, and it comes with mounting hardware. you will need 5 to 10 feet of #35 chain with master link and a chain tool, you will also need engine mounting bolts if you don't already have some.
patrick824
With the one you gave me the link to, I don't see if it is has a keyshaft... Does it have one?
r97
Massachusetts, USA
i'm sure it does, but if you'r really worried don't hesitate to e-mail bmi, they should e-mail you back later today if you get them before closing time.
