HF 13hp RPM tweak
FlamingChicken
Hello all,
I would like to use the HF 13hp engine for my gokart build, and I'm wondering how to allow more RPM (ideally around 4600) without completely removing the governor? Or do I remove the governor and install some sort of rev limiter? I guess the bottom line is: I want more RPM without the danger of over-revving, and I'm not too sure what my options are. If at all possible, I would like to modify the governor to allow such RPM.
Thanks,
Aaron.
I think the governor linkage can be played with to allow a higher rpm, yet still limit top end. I'm not sure exctly how. It has also been said that if you remove the governor on a stock engine, the valvesprings will cause and inherent speed-limit (valve float) well short of the engine detonating. While this seems safe enough on a flathead, I'm not entirely convinced that valve float is safe in an OHV engine. There may be a risk of piston-to-valve interference. Give it some time, someone here with more knowledge on this matter will pipe in sooner or later...
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
You cant limit RPM with gearing. You'll eventually over rev no matter what gearing you have.
You can probably get a stiffer spring to connect the gov arm to the throttle lever.
FlamingChicken
Remove the governor and limit your rpms with gearing.
Maybe you can explain this to me. I'm just building a basic frame, one wheel drive, 15" tires, 66t sprocket, and a 12t clutch. It will be driven on flat ground and I weigh about 150lbs. Do you think I will be in danger of over-revving?
Russ2251
AZUSA:Powered by LAWN-BOY
As long as there is always a load on engine, over revving will not be a problem. Take away the load...BooM!!! Rod goes first. Flywheel never fails unless altered.
Harmonics of a free running engine is what causes problems. Harmonics dissappear when in a loaded condition.
dpaxson
parma heights, oh
you'd want a softer spring for your governor and you can limit rpm with gearing if you gear your kart high enough that drag limits the top speed before redline does. it woudln't be practical on a 1 speed kart though
Oh, yes you can! If the vehicle is geared too high for the amount of power available from the engine, it will never reach it's theoretical top speed, even on flat ground with 10 miles of runway. in fact, I recently increased my top speed by gearing lower. Reduced the strain on the engine.
But- Chances are, you don't want to gear that high, acceleration won't be ideal.
devino246
Lynchburg, VA
Why a softer spring? The spring attatches the gov. arm to the throttle arm, so a stiffer spring would pull on the gov arm more.
slideways
If you take the tank off and get the linkage set up and working you should be able to understand how it works in about 5mins. Then its usually a matter of bending and tweaking on the governor arm or throttle arm area to get it to pull just a little bit harder on the spring and get more rpm out of it. I'd highly recommend buying a "tiny tach" so you can test it while you are riding it and get it where you want it. They're only about $40 and mine has come in handy lots of times.
