firemanjim
Just kartin' around....
It might work good now, but I think it will break at the worst possible moment, due to the strain/force it endures. That thing was designed to stop 2hp pocket crotch rockets weighing a total of 275pounds, with rider..... From 20-25 mph......If you are looking for a solid mechanical brake solution, I recommend this: http://www.pccmotor.com/dibrcapamipo.html
This is similar to what you might find on a bike, but bigger and stronger. I have this on the rear axle of my 20 and 17HP karts and they have no problem locking up the rear axle at speed.
You will also likely need a disk, so try this:
http://www.pccmotor.com/discrotors.html
Might require you to figure out how to mount to the shaft, but you might figure out a way to mount it to your sprocket. Use your imagination for shaft mounts.
Russ
The fact that it stops your kart is irrelevant. It's not safe, and I couldn't, with good conscious, recommend that brake , for a big kart...... I have some of those exact brakes. They do work great, don't get me wrong..... BUT like the ad says, designed for 49-50cc pocket bikes.... That's weedeater style engine, not 4 stroke.....
In time, the force exerted on the brake, will destroy it, and you, if you aren't lucky..... It just wasn't meant to handle a big load......
