Heres my $50 sand rail..go kart
kroncaddycustoms
Kroncaddycustomz
ontario,canada
so i basically have a rolling chasis now, i have a new gx340 337cc honda motor 11hp, i tried a centrifugal clutch (sprocket style) straight from motor to axle, burnt it out within 5 mins from the lack of gear ratio, what kind of clutch should i be looking into , i strictly want torque , would be happy if it went even 15mph as long as it has accelration, me and son go threw trail slow with ruts and mud and small hills, the kart is 6 feet long, any advice would be appreciated, i am making a truck body out of tin once i get this thing moving, thanks
r97
Measure twice cut once
Massachusetts, USA
:iagree:
search the forum for "comet 40 series", you can find a lot of information on that particular clutch setup.
$50 is an amazing deal!
kroncaddycustoms
Kroncaddycustomz
ontario,canada
ok thanks i will definitly check into the comet series, with that style i would have to put a jackshaft in aswell correct? i need to know what size sprocket for jackshaft and axle sprocket, it currently has 37 tooth, i built the whole chassis from round tube and front and back of 110cc atv
kroncaddycustoms
Kroncaddycustomz
ontario,canada
i found a gs550 bike engine for under $200 runs great, if i was to put this in my buggy what electrical do i need off the bike to go with the engine to make sure it runs,? is this a decent engine that will provide good power?
anderkart
Surprise Arizona USA
You'll need the CDI box, Ignition coils, Ignition/kill switches, starter button and solenoid plus all related wiring.
When converting a motorcycle engine over to a kart its really best to buy the whole bike so you could re-use portions of the frame for your motor mounts, get the pipes, airbox/filters and maybe even instal the bike brakes on your kart. With an engine like that you'll be needing some serious braking power...
Even If you had to pay a couple hundred more for a complete running bike, you'd probably end up saving money, aggravation and lots time over just buying the engine.
