Ok, so looking at what 'works' out there in the engine scene, just to add to whatever everyone else is saying:
a 20mm round slide works good on a stock valve briggs flathead: (tried it out this weekend haha- looks like a briggs L206 knock off
https://www.ebay.com/itm/Carburetor...e=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649
Briggs valve size is 21.5mm
A 22mm roundslide works good on the clone/predator 212's with mild modifications.
Predator gen 1 25mm intake
predator gen 2 (hemi) 27mm intake
predator gen 3 (non-hemi) 25mm intake
Clone/Gx200's 25-27mm intake valves
Open (highly modified) predator/clone/gx200 engines can take a
24mm flatslide
predator 301, gx240/gx270 can take the
28mm flatslide
predator 240/270 has a 29mm intake valve size
gx340, 390, predator 420, 10 bolt sidecover 440, and 460's etc can take anywhere from a
32mm flatslide, or 34mm round/flatslide
honda gx390 has a 36mm intake valve size,
Highly modified 340's, 390's, 420,s 440, 460's etc can take a
33mm pumper, or a 38mm carb. These typically have 38 or 40mm big valves put in.
Seeing the pattern? Take the intake valve size and get a carb with a venturi about the same size, or a tiny bit smaller, and you have yourself a carb that gives you the best performance. Bigger isnt always better, just get one that fits the intake valve size.
If you get a carb that has a venturi larger than the intake valve size, your low end will suffer, but you will probably get a boost in performance only in the top end. If your carb flows more than your head allows, then its really not the weak link. It should flow the right amount. Too big=sucky performance at a driveable rpm range.
Also, after reading about what head/valve size. I can tell you from experience that a stock hemi head is better than a stock clone head just because it flows better and has bigger valves.
If you are getting bigger valves, you better have bigger INNER DIAMETER seats. or you just killed more flow. If you take the same seat, and put a 27mm valve on it and a 28.5mm valve on it, the 27mm will flow better because the 28.5 has an extra 1.5mm to flow around.
What I think russel does at nr racing is take a seat that is already like 25 or 26mm, and cuts it so the inner diameter is 1 or 2 mm bigger and puts in a slightly bigger valve, but then keeps the exhaust valve the same, then does his multi angle valve job, porting etc. Just what i think he does, not sure about reality.
Annnd thinking about what nr racing has said about cams, it seems like the 1.3 ratio rockers, or any ratio rockers really dont give you much improvement on a short duration, low lift cam anyway (which is the one you are looking at). I think i read somewhere that the best combinations are 1.3 on a 275ish cam, 1.2 on a .308, and 1.1 or 1.0 on a 356.
From a seat of the pants feel. I really like the 280 2011 grind, but then sometimes i feel like im missing out on rpms too.
