help?!!
DirtTrackRacer_07
DeeR SlayeR
tennessee
What is it on and how do you got it hooked up?
You could put a return spring on it so that while you have it at high throttle, the spring would be pulling against you while you are pulling the throttle the other way.
kendelrk
redneck engineer
westland michigan
the engine is governed, and on my clone, when i put it full throttle the butterfly shakes back and forth not giving it full throttle
Russ2251
AZUSA:Powered by LAWN-BOY
jeez, ANOTHER clone problem?
Clones are not the only power plants to suffer from EPA lean outs. B&S probably has the most problems.
Sometimes can be cured with fuel injector cleaners.
Tolerances are very close on some jets. The smallest amount of varnish can cause problems.
Bluethunder3320
yeah its not like b&s is making engines any better.....
and this is why i like good old flatheads.
Bluethunder3320
i meant to say:
its not like B&S is making engines any better than the clones are. maybe a lower defect rate, but as far as being lean as can be and cheap parts.
kendelrk
redneck engineer
westland michigan
it wasnt under load at the time, with load it was surging, i guess im still learning my way around this sorry people. and clones are okay i like them, i actually went talking to a guy at studz hardware they sell go karts and stuff and yeah, but i pulled the throttle linkage out of my bad and the dude takes one look at it, and hes like this is for a honda clone, did you get it at harbor freight? and i was like yeah and hes like how much did you pay? i was like 80 and he was like thats a deal hes still selling the old clones too without the L gas tanks, it was pretty great, they sell go karts, mini crotch rockets, atv's, motorcycles it was pretty great. ill be going there alot more
