Help!!!!!!!!
8urn'7
Why wont it start?!? This stupidfrickin briggs motor wontstart!!!! I can pull it andpull it and it just wont start give me answers!!!!
8urn'7
i have fuel tank is fueled up and spark plug is good. now is the switch supposed to be connected to something i can find a close picture of the on off switch? would be greatly appreciated
8urn'7
White smoke coming from 5hp briggs motor??
OK so i got this motor from a friend and it had been sitting for awhile so i poured out the oil and gas and put in fresh also i changed the spark plug. now when i try to start it it makes a popping noise and white smoke starts coming out the carb. what is it. someone please help!!!!
8urn'7
now theres white smoke coming from the carburetor when i try to start it. whats happening?
amcjavelin
amcjavelin
western maine
if you got fire take a teaspoon of gas put in the spark plug hole and it should try to take right off now if your plug is black colored wipe it off good or replace sometimes i had instances where just replacing the plug will be all the difference in the world i know in the world of 2 strokes this was a common thing that would happen
amcjavelin
amcjavelin
western maine
thought you said you had fire, well take plug out leave it plugged on the wire lay it on something metal pull it over and you see spark on gap of your plug or hear a nice electriacal snap before you do this make sure the gas is out of the chamber first if you dump in before hand
