Yea it just needs a piece if brake cable to connect the two idk if it has something to secure the cable on the throttle body side thou it been a couple years since I messed with one these I stick with my Briggs and hondas......I would run a piece of shoestring from the throttle body through the loop by the carb then run a twist tie from the string to the carb but I'm a redneck and improvise any way I can
