Britcom61
I am new to this forum and don't have a lot of experience with go-carts. I just bought a 32001 Yerf Dog with the 6hp Tecumseh, it runs OK on the flats, but just a little of an incline causes the clutch to slip, it gets so hot that its melting. I have taken the spring loaded side of the clutch apart and cleaned it, made sure it moves freely. Then I moved the motor back a little to take up the slack in the chain, however, that did nothing to help with the rubber belt not gripping. I am not sure if this is the correct belt, it is a Powerlink 743 20, any help would be greatly appreciated. I am attaching 3 photo's, one of the clutch with the motor off, one while running, and one of the clutch setup. All taken with the belt removed, I do have the aluminum cover box to replace once I figure out the problem.
