GreenSalami
- Messages
- 1
- Reaction score
- 0
Hoping for some advice.
I converted an old pedal kart to add a motor from a cordless drill (Ryobi 18V). I know there are better motor option but this is the set-up I'm trying to make work.
Anyhow, I've got a 10T motor sprocket going onto a 40T axle sprocket with #25 chain. Got 10" wheels and the whole thing isn't too heavy, maybe 20-30lbs? Drill is set to #1 setting with max torque, low speed.
When I run the motor with no one sitting on it, it works fine. If anyone sits on it to ride, my 35lb kid or me (definitely more than 35lbs) - it sounds like the motor skips. All the gears/sprockets are secure in place, nothing is slipping. My gear ratio doesn't seem too high? Is it just that the drill is not powerful enough? I've seen some run on harder gear ratios than mine. At this point I just want the thing to work, willing to sacrifice speed, etc.
