Help with Predator Engine Part?
courts94s
Noob
Fort Sill, Ok
I broke off the plastic piece that moves the choke valve open and closed. I'm not sure what it's called or where I can get a new one. Anyone have an idea?
I just move the choke valve "wide open" and it seams to stay that way. Is that bad for it, or does it not matter?
---------- Post added at 09:04 PM ---------- Previous post was at 09:01 PM ----------
This little black thing is what I broke.
The choke rod has the vane staked in... You will need to make a tool to press in those dimples... In order to install/remove...
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Usually it is open all the time, Just sometimes needed for starting, Especially in cooler weather.
So you may be fine. If you can manually open it if needed you will definitely be fine.
Joe-405
Enjoying New Projects
U.S.A.
Your in the same state I am............ Your gonna need that choke to work !
courts94s
Noob
Fort Sill, Ok
That part is only about $3, but the shipping was $8... So I just cut out the back side of the black plastic piece below the air filter. Now I can manually move it, to choke and start it, then move it back to open.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
That works!
Like a car with a quirk. Nobody else can start it if they do not know the trick.:thumbsup:
Jfive
Great falls Montana
You could always cover the air filter to choke the engine if you need it ever and just remove it.
Pull the air filter off, and cover the intake with your hand to simulate a choke.
Once its running remove hand and reinstall air filter. If u don't wanna fix it.
courts94s
Noob
Fort Sill, Ok
That's way too much work, when I can just use a finger to open and close it.
Joe-405
U.S.A.
If you were closer to okc area I would give you one. I have a huge tub of junk carbs at work.
