Help With New Kart Build
NotSoMasterMind
South lyon michigan
https://www.gokartsupply.com/sprocket.htm
This seems to be a pretty good website as far as parts... I was looking through there gear/sprocket selection (I think I linked it properly, not sure if it is the right page sorry) and I only saw 3/4in and 5/8in "jack shaft" sprockets (which I assume are the ones that go on the motor) and the "jack shaft" on the golden motor BLDC motor is 20mm ~13/16in... (3/4in ~19mm) I assume I cannot buy those because 1mm is rather significant correct?
I will most likely use that website for the bigger sprocket and sprocket hub that will go on the axel (just have to wait to get the actual kart so I know what size axel it is)...
I played around with the gear ratio and speed calculator. I know it isn't accurate because it doesn't factor the unique weight or drag of your kart, but it was a good ballpark... Will play with it more when I have a better idea of what gears I will get.
I started looking into tires and stuff, was looking at the "Turf" tires... Just wondering what size I should get..
http://www.gokartsupply.com/tires.htm
Here is a link to the page, is there another type of tire I should consider? I just want a pretty inexpensive tire that is going to be relatively easy to mount to some rims and will get pretty decent grip on road. (I may do some off-road stuff in my back yard but I think for the most part I'll stick to asphault) My preference would be to get a set of 4 tires mounted on rims for under $50 but I guess that's not really reasonable so maybe $75...
I went for the turf style because I figured if I went for the slicks they might get more grip on road and I sort of want to drift/peel out if possible. Also, the slicks looked more expensive. Y'all know way more than me about this so please give your input if my thinking is wrong!!!!!!!
Ben
Always remember that the smaller the tire=more acceleration but less speed and easier for the motor to move the tires
Now, the bigger the tire=more speed and better offroad capabilities
