Help with my series 40 torque converter
ruffpie
I recently purchased an 08 Manco 710L with a Subaru Robin 10 HP and a series 40 torque converter. Overall in good mechanical condition but I am having a terrible time with the torque converter. After a little riding the belt starts to jump and kart jerks. On two occasions I had the movable sheave on the drive unit jam out due to a cam wheel dislodging from the track. I have no power on moderate hills and after very short time riding the belts starts to jump on any acceleration.
I have fully disassembled the drive unit and cleaned it. I haven't lubed it since I don't have a dry lube at the moment. I have disassembled the driven unit and cleaned it. I have noticed talk about adjusting the spring tension but I am not sure how to do this. The spring had no tension on it when I first took it apart. On my Manco the fixed sheave of the drive and driven are on the same side and I have the yellow spring in the driven unit. I am not sure which way I should wind the spring or for that matter how many valleys I should advance it. Finally the driven unit had some rust on it. After sanding it has some pitting.
The alignment seems a bit off to me but I am not sure if this is correct for my setup. Looking at Manco line drawing, I believe I have all the original spacers in place.
Any advice would be appreciated. The kids want to ride this weekend!
