He got it running but we don't know exactly what was wrong...
and neither does he!
What a let down and an anticlimactic thread.
In true grease monkey + mechanic terminology:
"Won't crank" = usually pertains to a vehicle with an electric starter. We say it "won't crank" when we twist the key or mash the button and nothing happens. Usually means the engine isn't moving or doing anything. If it's a manual starter that's big trouble, either the pull starter is broken or the engine is stuck/frozen or something like that, but you're unable to turn over the engine.
"It’s an pull crank 212 predator. Just won’t turn over (crank). Spark plug???"
"Pull crank" = pull starter
"Just won't turn over (crank)" = It was turning over and cranking but it wouldn't fire, start and run
He's got the vocabulary but he doesn't know how to use it. Possibly due to the fact that words and slang are very regional and certain words mean different things depending on where you are.
