T3clay
Hey everyone I'm starting to plan for a kart build this fall it will be my first kart not sure if I should start from scratch or a Craig's list kart.
Ok here's what I want an offroad kart l either a two seated or a one seated that my son can sit between my legs. I want to ride on gravel roads field drives pastures and trails. I'm most concerned with acceleration, I want it to go! High speed isn't super necessary 30mph would be good if I can hav wicked acceleration by obviously faster is better.
So the questions,
So suspension My initial plan had only rear do I need front suspension too?
Motor recommendation ?
Jack shaft? Torq converter? Shifter ?
Ground clearance? How much should I have?
Thanks for all the help
So the questions,
