So I found another engine on the junkyard, it's 8hp flathead. Only paid 5 bucks when you convert. It works great but problem is it is running counter clockwise. It has open pull rope ignition sistem
At first I wanted karting but with this engine it Is maybe better to go with go kart.
What do you guys think?
Yeah that is a fire extinguisher, that is going to be fuel tank, one more thing, the engine is very heavy. If I'm going to build a kart I need to put the engine on the opposite side then normal because of counter clockwise rotation
