Help with clutch and belt problems?
Connorh333
http://imgur.com/a/kMNRd
I recently received this go kart from a friend and have had lots of troubles with the belt and clutch. I bought a generic belt from autozone that was the right size but did not work. the clutch doesn't engage.
I believe it is a Yerf Dog 3203.
Any help will be greatly appreciated!
edit: it also has a 6.5 hp tecumseh engine and comet clutch.
BirdFanatic
Jonesboro Arkansas
I cant stress this enough you have to get the same belt that was originally on the kart you cant get something that only works partly because then you end up with crappy results :) i'm sure another person on here can tell you what one to get
From your pictures it looks like you have bigger problems than just belts. The primary clutch looks like it is coming apart and the secondary is questionable also. If it were me I would look into getting a new 30 series clutch kit and start from scratch. Also replace the bolt holding on the primary it looks like it backed out and bent.
