vintagebriggs5hp
- Messages
- 25
- Reaction score
- 0
I have this old race kart I put a 5hp flathead briggs on. I am having an issue getting the carb dialed in with the mods I have done. so far I have done open air filter, 3/4" header, Shaved eyebrows, and ported intake and exhaust. I smoothed out all the casting on the intake since they stuck up bigtime and widened the sides and roof quite a big. On the exhaust side I just smoothed it out not enlarging it any. I think since it flows alot more I need to rejet but am not sure what the stock size is and what the next size up I would need to drill to. I adjust it to 1 and a half turns out and it wont even start. I then turn it another 1/2 turn and it starts. Seems as though it goes back and forth where it like to run. sometimes it runs better all the way out and sometimes it need to be turned it a little. I know though turned in a little it has to be lean cause it backfires like mad and fire comes out the exhaust. What size jet should I go to? and will the stock jet needle work w/ an oversized jet? thanks in advance
