Help with brakes
mrbll48
I am working on rebuilding a go kart I bought a few months ago. Everything was going well until the brakes. I cannot seem to find any brake rotors that will work with the axle it has. The kart has a 1 inch diameter hex axle, and the only rotors I have found with hex bore are 7/8 inch diameter. I have been searching for a while, and I do not want to spent the money to replace the axle and all of the parts to go with it. Do you have any ideas?
gokartdaddy
MARYLAND
How about grinding the 1/8 inch you need with a dremel ?
You could mark the amount you need to cut in some manner instead of eyeballing it.
I have done some detailed work on a lot of projects with a dremel.
mrbll48
I had that thought, I just wasn't sure if it would be unbalanced due to not being absolutely perfect. Definitely worth a shot though.
Ebrownie
Western Montana
Are you sure that your axle is 1"? Every hex axle I have ever seen is 7/8" or like 1 1/4. I'm not saying it's not 1", I just want to confirm that you are certain that it is 1"
mrbll48
When I measured the diameter of the flat side to flat side it was 1 inch diameter. I would just buy a new axle if it wasn't for all of the other parts that I would need to replace.
anderkart
Surprise Arizona USA
You could cut the drive end off of a deep 1" socket, so it would slide onto the axle and adapt from hex to round, then machine the O.D. of that socket to perfectly fit the I.D of a rotor hub made for a larger-diameter round axle.
Then a keyway could be machined into the socket, and everything secured to the axle with a long setscrew(s) through a hole drilled in the socket.
Brake rotor hubs are commonly available to fit 1-1/4", 40mm. or 50mm. diameter round axles...
A socket is an excellent idea...
A deep impact socket, will have enough meat on it to bite the shaft and have surface to weld onto. An impact won't have a hard heat treat to it, and will be less likely to crack when the sprocket is affixed, and used.
Tom Knight
Metal fabricator/welder
Sunny Las Vegas, NV
Hey, BMI has a 1" hex bore wheel hub 4 bolt pattern on sale 5 bucks ! P.N. K260052 should work with little fiddling , 4" bolt pattern....old dog
mrbll48
Just ordered it, I will update on if it works once it comes in. Thanks for the ideas, I will definitely post pics once I get it figured out!
