raposak
2012 Build-Off Winner
In the cart i'm building, i'm running front yfz450 Calipers and a single Polaris predator 500 caliper in the back. In trying to research master cylinders, I figured why bother with the little single port one you are most likely to find for our application and go with a car manual M/C. In doing some research, I found that a 1980 Ford Fiesta has a nice little M/C with a bore size of .698 which is slightly larger than 5/8" but it comes with multiple ports so I can run the front seperate from the back. Here is a link to the one i'm looking at. Do you think it will work out for my setup? And I also have space in front to mount this directly in front of the pedal.
http://www.autozone.com/autozone/parts/Fenco-Reman-Master-Cylinder-Brake-System/1980-Ford-Fiesta-Import/_/N-im2u9Z8kn47?itemIdentifier=718932_0_0_3482
