Help with a drive train for a newbie
C2bloom
So I am really new to this but got the itch to make a kart. As you can hopefully see from the 2 pics I have this is my current drive train which does not work at all. The clutch is not powerful enough to push my 400 pound kart with 25 inch wheels. This clutch just smokes. It is a 13hp HF motor as well.
It just does not move with me in it at all, and it definitely will not move with a 2nd person.
I need some ideas as to how to make this work. Should I convert to a 40 series comet TC setup? I believe I would need a jack shaft then. Is there a way to go from the 1 inch bore on the motor to the 1 inch bore on the drive shaft directly with a TC??
Any input would be helpful.
Ohh yea... It is a 60 tooth on the axle, a 17tooth on the clutch and it is a hilliard 1inch rated for 13hp.
anderkart
Surprise Arizona USA
Man, those 25" rear tires are killing your gearing.
You would have been much better off buying a 1" bore Noram Enforcer clutch with
a 10-tooth driver gear:--> (http://www.out2win.com/catalog/noram_enf.html) instead of that 17-tooth hillard.
But a 40-series torque converter w/ a jackshaft, or some radical jackshaft gearing with your hillard would be your best solutions (in that order) now.
Or If you wanna try and save some money/work, you might be able to find a humongous
rear sprocket here at this link:--> http://gokartgalaxy.com/sprockets_&_sprocket_hubs.htm
With a kart as heavy as yours without a T/C or jackshaft, you'd want as huge of a rear sprocket as as you can find. But huge rear sprockets tend to have more problems with the chain coming off, so you might end up also needing a spring loaded chain tensioner system as well.
Are you running a #35 or #40/41 sprocket/chain sizes now?
Here's the links to #35 and #40/41 sprocket diameter charts:
http://www.azusaeng.com/Sprockets/AzSDno40.pdf
robbie
Osceola, Missouri
With huge tires and your gear ratio at 3.5 : 1 you're not even close to the right setup. You should aim for 8 to 1.
You could get that with a theoretical rear sprocket with 136 teeth, which isn't going to happen. What's really killing you is the number of teeth on the clutch, but you're not going to find one with few enough teeth since you have such a large engine shaft. Even if you could get one with only 12 or 13 teeth that would still give you a 4.6 to 1 ratio. It's just not going to get any better without adding something in between the engine and the axle.
To help you determine your best course maybe you should do some cost comparisons. Adding a jack shaft with 25 teeth on the input and 10 on the output would make a total ratio of 8.75 to 1. Even with big tires you'd still be able to peel out and not fry your clutch. Your top speed would be somewhere around 30 mph if you still have a governor, or around 42 without. Sounds like a lot of fun. And with so much horsepower you would be able to carry two people.
For cost comparison purposes, whether you install a simple speed reduction gear train or a torque converter, you will need a couple of bearings, a shaft, and a place to install them. Other than that, you're just comparing the price of a pair of sprockets against the price of the torque converter. If you want to go cheap, use sprockets and install the shaft in exactly the right place to accommodate a torque converter later. I'm sure that somebody on this forum will be able to tell you exactly where to locate it.
C2bloom
I am looking at the 40 series converter and using a jackshaft. Can i keep the 60 tooth on the axle and put a how many tooth sproket on the jackshaft to power it to get the correct ratio??
Thank you guys
I guess I am asking how many teeth should be on the jackshaft and how many teeth on the live axle?? I would re-use my 40 chain and use a 40 series TC
robbie
Osceola, Missouri
I don't know if you need any more advice, since you've already received good advice that will give you satisfactory performance. But there are just a few more details you may find helpful.
How fast do you want your kart to go, at top speed? If you want to go 30 mph you can set it up for this speed with a gear reduction jack shaft or a torque converter. If you use the torque converter, you'll get extremely improved acceleration, likely beyond the ability of your tires to grip the ground. In other words, you're likely to peel out a lot. Using a simple two-gear jack shaft set up for 30 mph will give decent performance all around. Probably good enough for just about anybody.
If you want to go faster the torque converter will give you the added speed, but not if you put an 8 tooth sprocket on the output. Doing that will give you a top speed in the 30s.
The top speed ratio on the Comet 40 is 1.05 to 1. This is close enough to a 1:1 ratio, so ignore it. What you want to do is go to the speed calculator http://www.diygokarts.com/vb/showthread.php?t=9591 and use the equation that solves for gear ratio. Put in your tire size, your preferred top speed, and the engine RPM that you want to hit at your top speed. This will either be 3600 with governor, or 4500 if you're a careful driver, or somewhere around 5000 if you plan to remove the governor and tromp on the pedal. Anyway, put in your numbers and solve for the gear ratio.
When you get the number, divide 60 by this number (because of your 60T axle sprocket) and the answer will tell you how many teeth you want on your jack shaft output.
Clayton
Saskatchewan, Canada
I have a mini bike with 20''s, it is geared 10:1. Just saying. TAV is the best bet to get best performance out of your engine, jackshafts can just be a hassle.
C2bloom
can i just put the drive clutch on the motor and the driven pulley right on the live axle?? I know it might be a pain with the belt and tension and to replace but is it possible?
