help with 49cc engine please
wavboy
hot springs
i have a 49cc pocketbike ok this is wat happens punp the gas into the carb spray starter fl pullstart it it start pull down the choke pull the throttle and it dies ok this another method i tried i pour gas down the sparks plug hole start it i get on pull the throttle and take off about 10 ft or so and it dies tell me wat u guys think do i need a new carb or wat please let me know wat u think
B.M.800
TheBeal.
Central PA
Sounds like a carb problem, however I cant say for sure if it just needs adjusted, or taken off and cleaned.
augidog
check your mixture setting:
run the mixture screw all the way in until lightly seated (count how many turns it took as a clue), screw it back out 1 3/4 turns...that puts you at a good starting point, you'll prolly end up slightly leaner (screw in) by the time you find the sweet spot.
Mrrcarney
these things need to be steaming hot before they will go
start it hold the rear wheel up and slowly increase the gas
adjusting the choke as needed when you have about 3/4 open choke and can go from idle to full throttle without bogging down
drop the rear and hop on
works like this on mine
wavboy
hot springs
thanks guys will try everything
before posting this on here i did take the carb apart and clean and trying to get that sucker hot wont even stay started but the mix scew i did not try were is the mix screw on the carb thanks let me know wat else u guys think:thumbsup:
augidog
pictures help
how about a pic of your engine? if the mixture screw's not evident, you may not have the engine i'm thinking of.
this is a 49cc, it has a diaphragm carburetor, and the mixture is adjusted with a screw on the side of the carby:
this is a 47cc, it has a bowl carburetor, and the mixture is adjusted by changing the position of the clip on the needle:
robbie
Osceola, Missouri
You're not getting gas to the carburetor. Check for cracked lines. If you have a diaphragm carburetor, you may have a hole or crack in the diaphragm. If you have a float carburetor, the needle may be stuck.
Or, your shutoff valve may be closed, if there is one.
wavboy
hot springs
i will post pic of the engine or mabe even a video si u guys can see wats going on:iagree: i hav the first engine 49cc thanks for the pics
